Close to starting Super 55
Chief 83
10-25-2006 20:13:52
I'm just about ready to see if it will run. Injector lines are back on. Need to adjust the rockers, put oil in it and connect up a fuel tank. No radiator just looping the hose. Once it runs we'll get serious about the rest of it. Other than the basics anything else I should be aware of before hitting the switch? It's diesel.
J Schwiebert
10-26-2006 04:08:39
 Re: Close to starting Super 55 in reply to Chief 83, 10-25-2006 20:13:52
Make sure you retorque the head after running it to warm up for at least 20 minutes. Did you check the valve recession before you put the head on?
chief 83
10-26-2006 19:24:16
 Re: Close to starting Super 55 in reply to J Schwiebert, 10-26-2006 04:08:39
Everything with the head seems to be about perfect. I'll let you know the results.
