clutch stuck 1800 B
Jeff Oliver
10-22-2006 10:52:09
Went to pick up my tractor at the repair shop yesterday for having the injector pump checked. Hopefully the fuel in the oil probelm is gone now. However, I got on the tractor and started it,went ot put it in gear and the clutch is now stuck. Tried riding the breaks nad breaking it loos but that didn't work. It sat outside for about a week after they got it finished in which time it rained some. All the covers are on the bellhousing and all but it won't move. When you take the plate off of the top of the housing and work the clutch pedal you can see the back of the pressure plate. There is a part of it you cna see move back but not the part that hits the flywheel.
I don't really want to take it apart if I don't have to. Luckily is is a direct drive so there is no Hydra power unit to deal with. Question is, and i know this will sound silly but, can I take the started out and spray the flywheel good with PB blaster or something and get it broke loose? Then spray everything again good with something like brake or carb cleaner to get the oil off of the flywheel?
I have a ford diesel truck that got a bad leak one day and got fuel all over the clutch.It took a week or so but I used the brake cleaner on it and got it dried off finally and I can't tell that it hurt anything now.
If anyone has some good ideas on this let me know! It's a little cold here today so i am gonna start working on it tomorrow I think
dweaver
10-23-2006 09:16:19
 Re: clutch stuck 1800 B in reply to Jeff Oliver, 10-22-2006 10:52:09
Make sure that the throw out bearing is moving every clutch finger the same. I had a 1950 that lost the bolt out of one of the clutch fingers. It worked fine one second and then wouldn't work the next. I thought it was just stuck and worked for hours to get it unstuck. There should be three fingers to check. I also had an army 6x6 that cracked the clutch finger. Same symptoms. It only takes a couple of minutes to check.
Jak
10-22-2006 18:35:44
That ole 1800 is gonna fight you all the way aint it?We have a 950 JD at work that has stuck several times and I had bossman pull me in a higher gear and press the clutch down,it breaks loose without too much problem.Got them 3 and 7/8's ordered yet for the 88?Jack.
Jeff Oliver
10-23-2006 03:03:16
 Re: clutch stuck 1800 B in reply to Jak, 10-22-2006 18:35:44
haven't got them ordered yet. Heck at the rate this 1800 is going I will probably have to put a clutch in it,for everyone else out there pullling it will unstick one but theway my luck has run with this thing.....:) Yea I am gonna try to do some things to it before taking it apart but I guess with the way things have gone on this tractor I just don' get my hopes up too much.
How you been doing? you gonna be ready for Tunica? I heard there will be Miss. Soul Food there.....
Jak
10-23-2006 07:22:13
 Re: clutch stuck 1800 B in reply to Jeff Oliver, 10-23-2006 03:03:16
I plan on going Saturday and spectating.I am gettin around but slowly.A.P.has sent me some get well cards and some interesting emails to help with boredom.Your Oliver Heritage Mag has helped too.Holler anytime Jeff,you know I ain't doing much.Jack
Jeff Oliver
10-22-2006 18:11:55
thanks everyone! I'll try all of this and if that doesn'twork I'll try the chain and tree. Although you have to remember this is an OLIVER, might not be a tree big enough to hold it! LMAO!!!
hoot 66
10-22-2006 17:57:03
If you can seeit then hold the clutch peddle down and take a long screwdriver and just pry the plate from the flywheel.I should pop loose.
Jeff oliver
10-23-2006 17:48:00
 Re: clutch stuck 1800 B in reply to hoot 66, 10-22-2006 17:57:03
Sprayed it with brake cleaner and it looks like it is away from the flywheel but I can't see it under the frame of the pressure plates. Gonna soak it a few more days then probably try the tree and chain.
Oh well in this process I am teaching a young lady who is interested in tractors how to work on them also so it's not all bad. We don't have to have this tractor now so it's not a rush job.
Next after the clutch? Gremmer power streering unit..! LOL!!!
J. Schwiebert.
10-22-2006 12:57:39
Find a large tree and a good log chain. Put it in low gear drive ahead with the clutch petal down. J.
Jeff Oliver
10-22-2006 14:42:53
 Re: clutch stuck 1800 B in reply to J. Schwiebert., 10-22-2006 12:57:39
considered that too. Might do that in a few days when the ground dries up some. One other thing, Before this last time in the shop when the tractor had been used for an hour or so and gotten good and hot if i turn it off it won't restart until it cools off. Motor will turn over but it won't fire.
I was thinking it might be in timing but am not sure and since they had the pump off again and the clutch is stuck I can't try that yet. Any other ideas to look for on that?
Matt Kane
10-23-2006 18:02:58
 Re: clutch stuck 1800 B in reply to Jeff Oliver, 10-22-2006 14:42:53
If the pump has been checked, how does it start? My tractor didnt want to start when cold and once warmed up didnt want to start, but ran fine once started. My timing was off. Now its fine.
old
10-22-2006 15:22:33
Block the clutch pedel down for a few days. Also you can pull the starter of that plate and spray the clutch area with brake cleaner to help free it up. Pretty common problem on tractors
