no oil pressurue in rearend
o
10-20-2006 17:52:55
i have a 4-78 fork lift with foward revserer,the oil in the rearend was alittle milky so i changed it when i took off the oil filter there was no milky or any oil in the filter that was on it for a long time just got it so i was changing fliuds,since the input shaft only turns when i move,with the foward revserer, it would move the oil around to lube it just using it around the yard? is there something common that may have happen to stop the pump from pumping,it sounds and runs ok,what to do? any help thanks john
