Super 55 temp sender
chief 83
10-15-2006 20:53:34
Forgot to add to my previous post. Diesel Super 55. The temp sender comes out of the block on the left side towards the back of the motor. The actual sender is out however what I think is a threaded plug is broken off flush to the side of the block. Three questions. Is that actually a threaded plug, what is the easiest way to get the remnants out, and where do I buy a new threaded plug--does it come with a new gauge set?
AB
10-15-2006 22:59:47
 Re: Super 55 temp sender in reply to chief 83, 10-15-2006 20:53:34
Korves 618-473-2855 and AgPartsFirst 1-866-246-9720 both have reproduction gauges and most any other new part you need for a super 55. Kent at 903-729-8349 has good used parts. I have purchased from and recommend all three. And yes, the new temp gauge does come with the threaded fitting.
chief 83
10-16-2006 17:59:03
 Re: Super 55 temp sender in reply to AB, 10-15-2006 22:59:47
Thanks! I feel better.
