energy cell removal
Max Edlin
10-15-2006 17:41:14
We want to remove the energy cells from a Super 88 without removing the injectors. The injectors were removed and cleaned about a month ago but we still have a miss in a hard pull. The I & T manual says that the body can be pulled with a threaded puller of 15/16 NF threads. A machinist neighbor of mine made one for me but it will not screw into the body of the cell. I think the manual is wrong and that it takes a smaller diameter puller. Need help with the correct size. Thanks.
J Schwiebert
10-16-2006 03:53:56
 Re: energy cell removal in reply to Max Edlin, 10-15-2006 17:41:14
What all have you done to the engine? How does it start and run otherwise?
Max Edlin
10-16-2006 15:17:36
 Re: energy cell removal in reply to J Schwiebert, 10-16-2006 03:53:56
The engine starts all right for a Super 88, a little ether in cold weather and it fires right up. The tractor is used for pulling only. It has 1650 pistons and liners and the gentleman we bought it from in Illinois told us do not turn the pump up any more. This is our third season of pulling and it has developed a miss when it is revved up. Any help would be appreciated.
Super 55
10-15-2006 21:59:16
It is suppose to be 3/4-18 for your tractor. It is tool ST 115-G. It is double ended, the smaller end is 11/16-20 for the Super 55, 66, and 77. If you want the pages from the manual on how to remove the energy cells email me.
