770 - 1650 switch
burrisnvolga
10-14-2006 16:00:52
I have a 770 gas and want to know if the diesel from a 1650 will fit , also will the wide front fit. Does anybody know if the rear axles are the same diameter. thanks Roland
dboll
10-14-2006 18:37:55
 Re: 770 - 1650 switch in reply to burrisnvolga, 10-14-2006 16:00:52
fix up the 1650, I had a 68 with direct injection and over/under , what a dandy tractor!
J Schwiebert
10-14-2006 16:50:26
How about a little bit more information. Also how old is your 770? If your 770 does not have Oliver power steering and the 1650 does the front ends will bolt up, But: How much work and money do you want to put in this project?
burrisnvolga
10-14-2006 17:14:32
 Re: 770 - 1650 switch in reply to J Schwiebert, 10-14-2006 16:50:26
my 770 is a 1962 and it does not have power steering. I found a 1969 1650 that has a wfe and 16.9-34 rears and a diesel 283 ci. My 38 inch rears are bad due to calcium chloride. I was also wondering if the flat top fenders would fit the 770, my shell fenders bolt to a flange on the outside of the axle housing. thanks for any help.by the way I haven"t went and looked at the 1650 that"s the reason for some of ?"s.
