Oliver 1265 Hydr. Leak
EasyG
10-11-2006 06:59:03
I am leaking hydr fluid from the right lift arm on my 3pt(where the shaft comes out of the housing). How difficult is it to replace the seal. The service manual is very vauge and I'm new to tractors. Any advice. Thanks
marty g.
10-16-2006 17:16:49
 Re: Oliver 1265 Hydr. Leak in reply to EasyG, 10-11-2006 06:59:03
Hello, Make you email available or send me an email at my address, I'll send you what you need.
EasyG
10-17-2006 04:28:45
 Re: Oliver 1265 Hydr. Leak in reply to marty g., 10-16-2006 17:16:49
I think this will have my email. Not sure exactly if I'm doing it right. I also tried to send you an email. Thanks again for alll your help.
Marty g.
10-11-2006 12:11:36
The lift cover assy has to be removed to free up the shaft from underneath. I have an exploded diagram of these parts. There is an o'ring at each end and a bushing at each end as well. I was told the bushings are 100$ a piece at the dealer and are probably worn if there is a leak.
EasyG
10-16-2006 05:38:38
 Re: Oliver 1265 Hydr. Leak in reply to Marty g., 10-11-2006 12:11:36
Anyway I can get a copy of that diagram from you, or can you steer me in the right direction to get one on my own. Thanks for the help.
