Oliver 77 pulling motor
Jeffrey Sharp
10-07-2006 02:50:28
I am thinking about a pulling motor for my 77. Iknow a Super 77 crank can be turned down to 2 inches from 2.25 to give it a .25 inch stroke. Can the stock rods be used? If I went to a 4 inch bore, what sleeves and pistons can be used? Bigger valves? If anyone has done this, I would appreciate a reply.
keddano
10-21-2006 09:49:51
 Re: Oliver 77 pulling motor in reply to Jeffrey Sharp, 10-07-2006 02:50:28
Jeff,Get ahold of Brad Maibach in Ohio 800-808-9934 He can point you in the right direction.
1.
I was told you can off set the 2 1/4 to 2in and use Farmall C rods with the stock pistons(I think that you have to bush down the pistons.)
2. The aftermarket 88 sleeves (like M&W 3 3/4" or 3 7/8") have enough meat to be bored to 4" and could be used with some work,with stock 77 rods and(I think from the mid 1980's Chevy 305 .060 flat tops)have the right wrist pin to deck height. Brad can fill you in. That is the combo I was looking into a few years ago.
P.S. Sent you a e-mail
Bryce
10-09-2006 06:01:50
Just put together a 4.125 x 5.25 77 ,using 77 rods.I would agree with the other posting about starting with an 88 UNLESS you want to go below 4500 lbs.Alot of places won't allow 88s under 4500.
Oliver Puller
10-07-2006 15:25:35
third party image
I am probably not very qualified to answer your questions but I will tell you what I know.
I used to pull an Oliver 66 and my uncle had a 77 and an 88. These were pretty much stock except the 77 had a big bore kit in it. His 77 had 3 3/4" pistons x 3 3/4" stroke. The 88 had 3 3/4" bore with a 4" stroke. His son asked me one day why we couldn"t stroke the 77 and I said we could but then we would have basically an 88.
So if it were me, I would start with an 88. They are not much heavier but have alot more potential. I don't think you can go any bigger on the bore with a 77 without boring the block. An 88 sleeve is bigger on the od so you could go a little bigger with them without boring the block. A sleeve from a newer Oliver such as a 1750 is the same size on the od as an 88 but is longer so you could use these if you cut them off and put another o-ring groove in them. You might not even have to cut them off as long as they don"t hit the crank. I know you can go to atleast 4 1/4" bore on an 88 if you bore the block.
Above is a picture of my latest Oliver puller.
