Oliver super 88 / 880 crankshaft
Larry Dawley
10-04-2006 07:14:21
Are the crankshafts in diesel motors the same as the crankshafts in gasoline engines on the Super 88 and the 880.Are the rods the same.Is the only differance the pistons and cylinder head.
Thanks Larry
J Schwiebert
10-04-2006 11:27:52
 Re: Oliver super 88 / 880 crankshaft in reply to Larry Dawley, 10-04-2006 07:14:21
The answer to that is one of those YES-NO deals. On the 880 the crankshafts are the same. On a super it depends on the age of them. All crankshaft are steel. All diesel crankshafts are hardened. Not all Super 88 gas engines used the hardened crankshaft. Diesel and gas engines did not use the same ring set either. They did use the same rods.
