880 Power Steering
OSB
10-01-2006 18:40:02
My 880 power steering almost doesn"t work. Does anyone know how hard is it to remove the unit and have it rebuilt? Would it be better to buy a repalcement rather than having the original rebuilt?
oliver gets it done
10-03-2006 11:31:27
 Re: 880 Power Steering in reply to OSB, 10-01-2006 18:40:02
turbine where could you get a replacement
J Schwiebert
10-03-2006 02:37:57
First of all we need more information. It may be as simple as a nut that came loose and is not allowing the valve to direct the flow of oil. I also sent you an e-mail.
P Heisey-Harleysville,PA
10-03-2006 01:32:34
OSB,
The late Oliver 770-880 & 1800-A series tractors used the Gemmer Power Steering unit. I stock vertical main shaft seals and O-ring kits for these units.I also have additional new and used parts for these units.
I supply these P.S.parts to Cockshutt 550-560-570-570S tractor owners.
Phil Heisey 215-256-8651 FAX 215-256-1203
turbin61
10-02-2006 15:50:23
buy a replacement, cause they are always leaking and usually don't work right..this is a very common problem on these tractors.
