540 pto not engaging grinding
Brian-1250
09-29-2006 06:21:25
Hi I am having a problem getting my 540 pto to engage it grinds when I try to engage it sounds like when you dont use the clutch on a car. The ground speed pto works fine.
This is on a 1250
Thanks
Brian-1250
09-29-2006 10:49:19
 Re: 540 pto not engaging grinding in reply to Brian-1250, 09-29-2006 06:21:25
Can you send them to me.
J Schwiebert
09-29-2006 10:39:51
Have you taken the inspection cover off the right side and checked the adjustment. As the clutch(s) wear it has to be readjusted. I have the dimensions if you need them. J.
