Oliver 88 Shift pattern
Sheila Cole
09-27-2006 16:38:27
I own all Allis Chalmers but recently purchased an Oliver 88 about a 1949 model.
Cant figure out gear shift pattern.
SM in Wi
09-29-2006 20:43:29
 Re: Oliver 88 Shift pattern in reply to Sheila Cole, 09-27-2006 16:38:27
Lets see if this works.
SM in Wi
09-29-2006 15:04:51
I hope this works
jake4
09-27-2006 21:27:17
There one shown on Ebay now at 4 bucks it shows the whole shift pattern get look free, its item 150039643988
jake4
09-27-2006 18:42:36
Its a bit confusing, the shift lever in center will push straight up or down putting in Hi or low range with a H pattern at both positions. The Decals are listed on Ebay ubder busines and equipment and Oliver tractor parts. The picture will indicate the gear and position. If needed I can scan a 66 plate which is the same.
Sheila Cole
09-28-2006 15:57:51
 Re: Oliver 88 Shift pattern in reply to jake4, 09-27-2006 18:42:36
Please send shift pattern.
Dave Sherburne NY
09-29-2006 15:54:21
 Re: Oliver 88 Shift pattern in reply to Sheila Cole, 09-28-2006 15:57:51
third party image
This is from a 1953 Oliver 88
R2----- --6
High ! Range 4----- -3
R1----- 5 Low Range 2----- 1 I thought someone would give this right away.
Had to go look at the tractor Thought you might like a look too.
old
09-27-2006 17:21:29
Its sort of a double H pattern. You have if I remember right 1st, 5th, 2nd and R1 in the low H and 3rd, 4th, 6th and R2 in the upper H. Theres a sort of an I in the center of the Hs to go from the low H to the upper H. Hope that helps some. Its hard to explain it on the computer useing a key board. Thats the same pattern used on the 77, S77, 88 and S88 and also a number of others.
