Oliver 1250?
EasyG
09-25-2006 06:23:12
I recently aquired an old Oliver tractor that I was told was a model 1250. The serial number is 321296 and the model number is 62522003. Both of these numbers are on a metal tag under the stering wheel. Is this in fact a 1250. The serial number doesnt seem to match the info that I am finding.
Hard Knocks
09-26-2006 05:38:39
 Re: Oliver 1250? in reply to EasyG, 09-25-2006 06:23:12
Is it a gas or diesel?
EasyG
09-27-2006 05:01:05
 Re: Oliver 1250? in reply to Hard Knocks, 09-26-2006 05:38:39
It is a 3 cyl diesel. Some other features that might help are that it has a diff lock, one set of remotes, a foot throtle. I think that it is a 75' 1265. Thanks for the help.
Hard Knocks
09-27-2006 05:09:45
 Re: Oliver 1250? in reply to EasyG, 09-27-2006 05:01:05
If its a 1265 you have a great little tractor that parts are readily available unlike the 1250 gas which was a bit of a lemon and no engine parts are available.
EasyG
09-26-2006 07:31:31
It is diesel. I didn't look to see if it was 3 or 4 cyld. I will have it tonight to get a better look at it and see if I can find any other markings or identifies. Anything I should look for. It has a metal tag under the steering wheel that has the model and serial number on it. Again they are Model 62522003 S/N 321296. Thanks to all of you for your help.
EasyG
09-25-2006 09:32:31
 Re: Oliver 1250? in reply to mn.Chuck, 09-25-2006 08:29:14
Chuck,
It could be. All the info I found said that the 1250's had serial numbers starting with 7 like you said and that if what has me confused. So it may be a 71' 1250A correct??
Thanks for the help
chparks
09-25-2006 15:48:35
 Re: Oliver 1250? in reply to EasyG, 09-25-2006 09:32:31
The two sources I have show it is a 1975 1265.
No other serial numbers go as high as he indicat
his is. Also 1250 has a 4cyl engine 1250-A,1255
and 1265 all have 3cyl. engine.
