570 super
Will M
09-21-2006 05:49:29
Thanks J. Where they tested as nebraska for hp?
Tony Sha
09-24-2006 08:40:27
 Re: 570 super in reply to Will M, 09-21-2006 05:49:29
A couple years back the Cockshutt Quarterly printed a leter from Cockshutt management to Hercules engine Mfg. for an order for engines and it showed a request for 72 hp.
Farmritch
09-24-2006 06:36:36
My buddy I help farm with, has one 570 with over 10000 hours with only head work done ( two times).
Never had pan off the bottom end A very super tractor indeed!!!
Farmritch
Neil Grant
09-21-2006 17:58:55
The super was not tested at Nebraska. The regular 570 was with 63.66 corrected belt horsepower. One would suspect it would be about 70 by ratioing up the displacement I get 72 hp.
The Super was one of the best tractors ever made. It had the H series engine with the heavier crankshaft than the old 570. The 560 and 570 had an even better drivetrain than the old 35-50. It had a good power to weight ratio with the standard tires loaded with one or 2 wheel weights.
The 500 series tested at Nebrasks made a very good showing for traction (550 pulled more than a 40 or 50 with less weight and less power) and fuel economy for the 560.
I may be a little biased as I have a 1962 Super which has been in the family since 1978. It has 7500 hrs showing on the meter with considerable use when the gauge was not working.
