Super 570?
Will M
09-21-2006 03:48:37
I know the hp and cid of a Cockshutt 570 what is the difference if any in a Super 570
J Schwiebert
09-21-2006 04:21:56
 Re: Super 570? in reply to Will M, 09-21-2006 03:48:37
The 570 is a DDH 339 engine(339 Cubic inch). The displacement is larger and since it is the H code engine it has a hevier crank plus other things. More questions? J.
Mike (WA)
09-21-2006 08:37:43
 Re: Super 570? in reply to J Schwiebert, 09-21-2006 04:21:56
I think its the 570 Super that has the 339- the straight 570 has the 298, if memory serves. But on that subject, another question- I've heard the 339 is just a 298 without the sleeves. Is that possible? I always figured that an engine designed for sleeves would have grooves for O-rings, etc, and wouldn't be usable by simply removing the sleeves and using larger pistons.
RAB
09-21-2006 11:50:39
 Re: Super 570? in reply to Mike (WA), 09-21-2006 08:37:43
You wrote: I always figured that an engine designed for sleeves would have grooves for O-rings.
No grooves, no O-rings in a dry sleeve engine. Lots of them about. Stiffer construction than wet liners. Perkins are one example.
Also lots of parent-bore engines can be fitted with dry sleeves to bring them back to original service specs.
Regards, RAB
