Carb Problem
Steve G
11-23-1999 19:16:41
My 1951 HG has a Marvel carb.It is run infrequently as it goes thru a slow minor restoration.I tried starting it the other day and it would only run for about 5 seconds at a time then die instantly.It would have to sit at least a minute before restarting only to die again.Seemed like a lack of fuel.It had fresh gas and fuel line was open.I later verified the line wasn't clogged.A friend suggested the carb itself could be the problem.I didn't have time to tear into it and wanted a second opinion before doing so.I'd appreciate suggestions, and what is a good initial setting for the idle and hi speed screws in terms of number of turns?Thanks in advance.
Tractor Guru
11-25-1999 08:11:03
 Re: Carb Problem in reply to Steve G, 11-23-1999 19:16:41
You definitely have a carb. problem. Some Marvel carbs had a screen in the inlet elbow. Your screen maybe plugged. I would tear apart the carb., by a minor repair kit and a can of spray carb. cleaner. Spray down the carb. good with the cleaner. Make sure all passages are open. Install new parts. Preset your needles a turn and a half. Put it back together and see how it runs.
Dick L
11-24-1999 07:37:28
Most likely you could get by with opening up the carb, remove the neddle valve and wash it out with a can of spray carb cleaner. Works for me with all the old stuff I have sitting around that I don't take proper care of.
