Other brand (JD, IH, etc.) ROPS fit on 1650?
Kerwin
09-15-2006 15:05:42
Has anyone put a ROPS from JD or IH on a 1650 or comparable Oliver tractor? From looking at pictures on this site, some of the other brands look similar in construction. I wonder if they weren't made by the same company with mounting pads different between the brands.
I haven't had any luck finding an affordable Oliver or White ROPS for my 1650, and thought something from JD, IH, or someone else could be professionally modified to fit.
j meyer
09-16-2006 08:55:56
 Re: Other brand (JD, IH, etc.) ROPS fit on 1650? in reply to Kerwin, 09-15-2006 15:05:42
You've actually found an Oliver rollbar for sale before? I have seen only one not on the tractor, and the guy told me that its not for sale and the last bar(less roof) he had he sold for 1500....so if you even find a rollbar thats true Oliver, your lucky, let alone finding a reasonable price on it. I saw one on here pry 3 years ago on the classifieds and I called him right up(ad was posted within the hour) he had it sold already. HARD TO FIND ITEM!!!
Larry from md
09-15-2006 16:17:35
I have done several myself. One was a MF the bolt holes on the bottem fit well when i added a few inches to the middle of the top bar. It is a little short though. I allso put an IH one on a 1600,i used the same way of fitting it.I removed the fender bases and the bolt holes fit and added a small piece to the top bar. The fenders were rusty on the bottem so i bolted them to the rollbar useing new holes higher up.
Dave Sherburne NY
09-15-2006 16:13:09
I once mounted a Hiniker cab from a 1650 on a JD 2520. Pretty good fit on the axle
