Covering a Silage Pile
Adam- WI
09-13-2006 14:43:55
Does anyone on here have any ideas what I could use to cover my corn silage pile? I would like to stay away from commercial bunker covers, they are too expensive. I have been busy chopping corn with my 1650 and need to get the pile covered with more rain on the way this weekend. We had about 1 inch the last 2 days and the top layer of the pile is pretty wet now.
dboll
09-15-2006 13:19:31
 Re: Covering a Silage Pile in reply to Adam- WI, 09-13-2006 14:43:55
our neighbor used to seed oats on his, clear plastic would make the biggest solar collector to date!!
buckva
09-14-2006 20:15:07
Big outfit near me uses the black plastic held in place by large round hay rolls.
newter haven
09-14-2006 19:40:50
We always used a black plastic at the old farm always worked out good. I think farmtek at 800 476 9715 can help they're reasonable. Good luck!
thhill
09-13-2006 18:36:16
I agree and the new stuff white top black bottom stuff is tuffer than the old black rolls we used to use. much easier to put tires on without puncturing. And the white on top doesn't get as hot as black.
Adam- WI
09-13-2006 16:15:34
I was thinking of using regular 6 mil clear plastic. What is the benefit of using the plastic that's white on top and black on the bottom? I was planning on using tires to hold the plastic down.
david hall
09-13-2006 15:46:08
This is a deal where you get what you pay for. For the trouble it takes, and benefits you get in protecting quality, put a real cover on. Most folks in South now use the type that is white on top, black on bottom side. Then cover generously w/ old tires to keep wind off. Suggest you put line of silage, lime, whatever around edge to keep wind out and seal.
jpsep
09-14-2006 13:13:54
 Re: Covering a Silage Pile in reply to david hall, 09-13-2006 15:46:08
Just cover it with wheat. It will sprout and makes a dandy cover.
