Super 55 Hydraulic pump
Matt Kane
09-13-2006 14:22:46
Anyone know if a V200 vickers pump would work, or will they only take a V120? I thought I have read that the later 550's had a bigger pump?
Matt Kane
09-13-2006 17:47:13
 Re: Super 55 Hydraulic pump in reply to Matt Kane, 09-13-2006 14:22:46
Numbers on the pump are V200 6 3C 12. The pump is on an old woodsplitter. It looked close, but I wondered, just in case I needed one. Once my garden is done, I"ll plow, then tear into the hydraulics when I dont need the tractor. The one thing I wondered, how does the shifter remove to lift the cover? Other than that, it might be an okay job. I plan on replacing all the seals and O-rings, and checking the condition of the pump.
J Schwiebert
09-13-2006 17:29:15
You sure that is not a V-20 pump? The width changes. Most pump manufactures for vane and gear pumps make the pumps in different widths thereby letting them use the same end plates, Questions?J
