Should I weld the center steering arm on my Oliver
Bearded Bob
09-13-2006 05:52:04
Yesterday the center steering arm on my tractor broke in half. What shoud I do ? Search for replacement part or have it welded by a machine shop ?
Bearded Bob
09-21-2006 10:06:44
 Re: Should I weld the center steering arm on my Ol in reply to Bearded Bob, 09-13-2006 05:52:04
My brother and I just completed the repair. He did a good job on the welding and since we were working on the center steering arm we took time to realign the front wheels. We had to wrestle with the tie rods, these things certainly can be stiff. Now all is fine and I thank everyone who replied to my questionning.
larry h
09-13-2006 18:11:46
you can get them aftermarket very reasonable
Luke S
09-14-2006 12:46:22
 Re: Should I weld the center steering arm on my Ol in reply to larry h , 09-13-2006 18:11:46
I agree, unless your time is not worth anything, I'd buy a new one as the one's I've seen are less than $100.
Don from Wi
09-13-2006 07:37:00
I'd weld it. V it out really deep, then just fill it in with a bunch of passes with Ni-cad rod. Chip & wire brush after every weld, and just take your time. I did a similar weld about 7-8 years ago on the hitch clevis of our JD disk because it broke clean off. It's still holding just fine.
If you can, put it in some DRY sand imediately after welding so it cools slowly.
Donovan from Wisconsin
IBorange in TX
09-13-2006 07:03:21
Pull the shaft off and take it to a machine shop.They can weld and true up the shaft,if it is a good shop. Good Luck....
