550 engine speed II
Jeff from IA
09-12-2006 10:45:51
I have the Bosch pump on my 550 deisel, even though it is a '61. I can only get to 1750rpm with the throttle wide open. If I, at the pump, push the lever up to the stop bolt, I can maybe get 1900rpm. What do I try next? Thanks, Jeff
J Schwiebert
09-13-2006 04:19:33
 Re: 550 engine speed II in reply to Jeff from IA, 09-12-2006 10:45:51
Well your spring tension is not correct. It could also be the wrong spring. Anyhow, hold the arm against the high speed stop and adjust the spring to get 2200 high idle no load. Just for fun check the numbers that are on the governor and post them here. Maybe someone put a governor from a different Oliver on there. Seen it more than once in this area. More questions? J/
