I don't have anythung to do for a while, so I thought I would look up the answers. You gave a very good discription of what you need, but your question applys to a 550. I will explain. The part number for the clutch lever is 1E-1659. The number for the lever link is 1E-1662 if it is straight,(super 55) or 104 133-A if it is off set (550). The number for the link pin is 1E-1644, with 6 used with the straight link. (25/32" long) The off set links use three pins (25/32" long)part number 1E-1664, and three pins (1" long) part number 104 134-A. It does't matter what unit you have, they all use a 3/32 X 7/16 spring (roll) pin, (not a cotter key) in the clutch pins to hold them in. The parts book only lists the part numbers, not the sizes you need. If it were me, I would try to see if it's a 1/4 , 5/16 0r a 3/8" dim. pin. Then go to your local hardware and get one of those pins that have a lot of holes in them, that you could cut to the length you need. Add a cotter key and be on your way. When you get time,you can order the correct parts and fix it correctly.
