oliver 1800 gas engine parts
jim wj
09-10-2006 06:16:20
I have an 1800 gas with a bad engine. I am woundering if anybody has an old engine for parts especially one with a good engine block.
J Schwiebert
09-10-2006 06:34:53
 Re: oliver 1800 gas engine parts in reply to jim wj, 09-10-2006 06:16:20
Pushing the button too quick. What is the problem with your block?
jim wj
09-10-2006 10:42:36
 Re: oliver 1800 gas engine parts in reply to J Schwiebert, 09-10-2006 06:34:53
casting numbers on block 157329a 221120c 1153
serial number of tractor 144661-822
model number
38-2145
the block from the tractor is cracked between 4 of the liners and there is also a crack running horizontal along the bottom of the water jacket. The water jacket crack i could fix but i am not sure about the crackes between the liners.
If you have some ideas on fixing this please let me here them.
thank you
J Schwiebert
09-10-2006 11:18:16
 Re: oliver 1800 gas engine parts in reply to jim wj, 09-10-2006 10:42:36
Are the cracks between the liners just at the top of the block? The crack on the outside of the water jack will be an easy fix. Now a word of caution: THE WORST WAY TO FIX IT IS BY WELDING. I sent you an e-mail. Let me know if you do or do not receive it. J.
jim wj
09-11-2006 19:45:21
 Re: oliver 1800 gas engine parts in reply to J Schwiebert, 09-10-2006 11:18:16
hi j I did not recieve the email from you.
please try again, Iam very interested
thank you J Schwiebert
J Schwiebert
09-10-2006 06:33:56
How about being a little more specific. The 1800 A series blocks will not interchange with the the B & C series blocks. Get us a serial number of the tractor Also casting numbers for the blck which are located behind the starter will help.
jim wj
09-14-2006 19:09:35
 Re: oliver 1800 gas engine parts in reply to J Schwiebert, 09-10-2006 06:33:56
hi j I have model and serial numbers posted. I did not recieve the email . thanks
