problem with hydra-shift 1950
SupC
09-09-2006 18:57:13
This hydra-shift was stuck when my buddy bought it, I got the spool freed up and it worked fine driving around with no load. Tried at the tractor pull and when you pull it out it just goes to a neutral point and won't pull. I tried it today around in the yard in a high gear, full throttle,standing on the brakes, sometimes it works, sometimes it just goes to neutral.Lower r.p.m.'s and no load it works fine and goes right in. Any tips on what it might be,or where to start on diagnosis. I've got ashop manual, was going to check the pressure and go from there. Also, if the clutch pack,etc. is bad is a rebuild kit available?
Dean Barker
09-12-2006 13:32:06
 Re: problem with hydra-shift 1950 in reply to SupC, 09-09-2006 18:57:13
I bought a 1750 that would stop moving about half of the time when I used the Hydra-Power in the low side. I changed the fluid to universal hydraulic oil, replaced the filter with 30-3475425, and that ended the problem. It worked perfectly for several years until I traded the tractor.
B A Star
09-10-2006 06:27:39
The problem is most likely the sprag clutch. There isn't any adjustment. Replace the parts. If you have a shop manual, it should show the power flow, Direct drive, hydaulic clutch is engaged, power goes straight through. Hydrapower, (lever pulled out)power passed through the countershaft to output gear which is coupled to output shaft through sprag clutch. Your sprag clutch and components are worn out.
Larry from md
09-10-2006 09:57:18
 Re: problem with hydra-shift 1950 in reply to B A Star, 09-10-2006 06:27:39
You could try changeing the fluid,if whats in there is too thick the spraggs wont engage right.
