J. Schwiebert perkins question
newter haven
09-06-2006 19:46:31
For a few seasons I have asked about a howl in my clutch pedal at higher r.p.m.s, have replaced clutch and throw out bearing some 300 hours ago but noise still persists and is getting worse. It seems that I have end play in my crank shaft, something to do maybe with a thrust bearing? Tractor is an '85 110 with 4400 hrs is this normal wear? Is the crank repairable or do I need a new one, Does it depend on if it's chromed or are they all chromed? Just some things I've learned in the last few weeks. Always looking for a second opinion of course. I don't want to ask how long I can run it in this condition but we're close to being done for awhile, I'm wondering what's the worse that could happen? Thanks for replying and all who do.
J Schwiebert
09-07-2006 08:25:16
 Re: J. Schwiebert perkins question in reply to newter haven, 09-06-2006 19:46:31
I though of a few other things this morning for you to check. Right now I have my suitcase out and will be gone untill some toime Saturday. See if you can get me a phone number. Thanks. J.
J Schwiebert
09-07-2006 03:40:09
First of all in 1985 I had been gone for 9 years so no hands on experience. The only 110 I ever worked on was for a man that worked with us and he had an oil pressure problem. Can you set up a dial indicator somehow and check end play? On the crankshaft, I used to have a AERA bulletin that listed probably a dozen 354 Perkins cranks and what was different about them. Sorry about little advice. J.
RAB
09-06-2006 23:12:11
If your first motion shaft is trying to do the job of controlling crank end-float it needs fixing as the bearing in the flywheel is not designed for axial loading - and prolly not the bearing on the g/box input either.
Everything is repairable at a cost. Just depends on degree of wear.
Regards, RAB
newter haven
09-07-2006 18:53:17
 Re: J. Schwiebert perkins question in reply to RAB, 09-06-2006 23:12:11
Thanks to both of you for answers - it seems to have about a nickel's worth of end play just guessing from the front pulley, may take the starter off on a rain day to check closer. J. I think I may have your phone number here I'll have to look, thanks again.
