row crop 60 smoking no power
kelyclo
09-05-2006 18:28:40
i purchased a rebuilt 60 row crop. it smokes a little at start up and then smokes some but not as much. the people said it would pull a sled real good for its weight. tractor sounds good no misses but it just doesn't have any power at all.
Ken L.
09-06-2006 16:54:25
 Re: row crop 60 smoking no power in reply to kelyclo, 09-05-2006 18:28:40
Add these to the other replies. Is the choke opening all the way? Is the air cleaner plugged? Have you checked the timing or valve clearances? Weak spark?
AB
09-05-2006 19:47:33
Just consider the tractor was tested at 17.85 corrected drawbar horsepower so it is not a powerhouse to begin with. You might try a compression test on each cylinder to see what you've got.
bradk
09-05-2006 19:18:21
What color is the smoke..blue or black?
Do you know what the so-called rebuild involved?
~brad
johnv
09-05-2006 18:54:35
sounds like either the oil rings on the pistons are tired, and or your carb may need to be adjusted, possibly even the float needs to be "tweeked" a little.
how do your plugs look, are they black, and do they have a major carbon build up??
