Solvent for air cleaner de-greasing
Kevin Roberson
09-05-2006 14:19:10
All,
I am fixing up an Oliver 550 Gas and am refurbishing the air cleaner. It has not been serviced in quite a while. The manual says to clean the "steel wool" by soaking in solvent, if it gets too dirty. Mine is very filthy with dirt and grease. What kind of solvent should I use? Thanks for your help.
Kevin R.
Mike (WA)
09-05-2006 14:33:54
 Re: Solvent for air cleaner de-greasing in reply to Kevin Roberson, 09-05-2006 14:19:10
Most everybody just calls it "solvent"- proper name is mineral spirits, I think- If you go to your local gas and diesel supplier and ask for "solvent- for parts washing" you should get the right thing.
Kevin Roberson
09-05-2006 14:36:03
 Re: Solvent for air cleaner de-greasing in reply to Mike (WA), 09-05-2006 14:33:54
Thanks, Mike.
