Loosening Bolts on 550 Coolant outlet
Kevin Roberson
09-05-2006 07:21:57
All,
I am not much of a mechanic, but I like messing around with the tractor. I have a 550 that is not heating up to working range and my thought is that the thermostat is stuck open. I took everything off to allow me to reach the coolant outlet fixture where it attaches to the head with three bolts. They did not budge. I sprayed them with Kroil and am letting it set for a while before I try again. Any hints if this does not work? Thanks for your assistance.
Kevin R.
Kevin Roberson
09-10-2006 15:24:51
 Re: Loosening Bolts on 550 Coolant outlet in reply to Kevin Roberson, 09-05-2006 07:21:57
All,
I got the bolts loose after 1 week of soaking with Kroil and keeping trying. I whacked them with the flat chisel. Now I am ready to put the beast back together. Thanks for your help.
Kevin
Kevin Roberson
09-06-2006 15:14:50
Thanks to all for the guidance. I will let you know how it comes out.
Kevin
RAB
09-05-2006 23:13:00
You wrote: my thought is that the thermostat is stuck open.
Just check it out first. There should not be flow through the rad until up to temp. If you can see flow, or rad is warm soon after starting, that might confirm your guess. How hot is it getting? The guage may be incorrect. They are not precision instruments, even when new.
Does it heat up more quickly when the radiator air flow is blanked off?
Find out before you break anything.
May not even be a thermostat fitted!
Biggest mistake is to dive in and replace everything before diagnosing the actual fault and then finding the fault persists. That is how a lot of vehicle service centres work - they just guess and expect you to pay for their mistakes. It may even be the block filled with sediment and insulating the sender unit if it has the expansion type fitted to the back of the block.
Regards, RAB
Kevin Roberson
09-06-2006 15:21:36
 Re: Loosening Bolts on 550 Coolant outlet in reply to RAB, 09-05-2006 23:13:00
RAB,
Good comments and I appreciate them. The radiator does heat up soon after starting. I needed to replace the radiator hoses and wanted to wash and flush the radiator. This machine runs great and everything works, but it has not had much maintenance.
jake4
09-05-2006 20:05:57
I have good luck using an impact wrench and using low air pressure, the slow blows gets them right out. The bolts won't be rusted in solid due to the application.
johnv
09-05-2006 19:23:36
since you have the thermostat housing out in the open, take a flat tipped punch anmd a ball peen and give each bolt a good "crack". this may break the bolts loose. also possibly the gap between the bolt and the housing hole may be jambed with rust. you may have to twist off the heads of the bolts and then take off the housing. the you can probably take vise=gripps and extract the bolts after taking off the housing
RockinB
09-05-2006 08:17:27
Try it after the motor is warmed up.
Kevin Roberson
09-05-2006 08:33:36
 Re: Loosening Bolts on 550 Coolant outlet in reply to RockinB, 09-05-2006 08:17:27
I had to take the gas tank, radiator, etc. off to get to the outlet.
Kevin
