inj. pump studs
meadowgreen
09-04-2006 15:28:17
Adjusting the timing on our 1755 and pulled one of the pump mounting studs out of front cover. How are these put in the cover? Can I get by running with two studs? Tractor is on auger.
J Schwiebert
09-04-2006 15:45:59
 Re: inj. pump studs in reply to meadowgreen, 09-04-2006 15:28:17
They are welded on the back side. We had one that broke one time. We had covers laying around, no big deal to change one. J.
dboll
09-05-2006 16:44:54
 Re: inj. pump studs in reply to J Schwiebert, 09-04-2006 15:45:59
I had a couple come out of my `1955 some years ago, removed the pump drive gear and shaft out in the middle of a corn field, took two 3/8 pan head screws put gasket material under the head and it worked for as long as I owned it!!
meadowgreen
09-05-2006 19:09:06
 Re: inj. pump studs in reply to dboll, 09-05-2006 16:44:54
Thanks for the replies. Will probably do something similar this weekend. I'm still having problems with no fuel when starting after engine is warm. Can rest hand on pump, so its not extremely hot(running auger). Pour cold water on pump head and it starts. Just installed a rebuilt head. Haven't got much hair left to pull. I think I need to find new pump mechanic. Starter turns 200 rpm.
dboll
09-06-2006 13:09:19
 Re: inj. pump studs in reply to meadowgreen, 09-05-2006 19:09:06
pouring cold water on a pump, especially a running one is kind of a no-no!
J. Schwiebert
09-06-2006 06:51:12
You could check the transfer pump pressure but I am almost thinking your rebuilt head is not that good. What are your injectors set at? J.
meadowgreen
09-07-2006 19:32:31
 Re: inj. pump studs in reply to J. Schwiebert, 09-06-2006 06:51:12
I wouldn't be pouring cool water on it if it would start! J, I'm also thinking the rebuilt head is no good. I believe he said he set injectors at about 3000 psi. Not sure. He did give me an inj. that was set at 2700. Warm engine, took no. one inj loose and put 2700 on. Bled line. Would pump fuel until I tightened fitting, but would not pop injector. Transfer pump was rebuilt Nov, 2004. Pump temp was 100 degrees tops. Put a cup of cool water on it and started. If sun has been shining on pump it won't start. I'm getting good at taking pump off.
