Tire size speed
Jim Meade
09-03-2006 17:25:40
If a tractor is sold 18.4X34 and the same model tractor is also sold with 18.4X38, is there a change in the speedometer gearing or does one speedometer show a little off true?
Farmer in the Dells (WI)
09-04-2006 06:54:27
 Re: Tire size speed in reply to Jim Meade, 09-03-2006 17:25:40
From my days in the tire shop, changing the rolling diameter of the tire will affect the speedometer. At least in the case of local trucks that changed to oversize tires. You can change one size to obtain the exact rolling diameter however we didn�t like to do it because it meant putting the wrong size tire on vehicle. When I was at Walmart Tire they would only let us mount the manufacturers recommended tire on. If you have a GPS unit available it will tell you how fast you are going (at least mine does) off the satellites. I have tested it against other speedometers and it is as accurate as I can do with having it calibrated. We also have local portable radar units that get set up in town. I go past them several times at different speeds to see how close my speedo is. You could compare. HTH
Don-Wi
09-03-2006 22:42:38
I would guess the speedo is going to be a little off. I widh the speedo on oour 1855 worked because then I would know for sure, but apparantly it threw the chain coupler a while back on the last owner so the whole speedo drive is gone and filled in with silicon... Our 1755 w/ 18.4-34's seemed to be accurate. Our 1855 has 38's on it but no functioning speedo.
Donovan from Wisconsin
