Cockshutt 540 Hydraulics
Allan Lance
09-03-2006 16:54:56
Hey Everyone
Just recently purchased a Cockshutt 540 and I have a few questions. I read somewhere that these tractors came standard with three point hitch and hydraulics to run a remote trailing cylinder on a disc or cultivator. However when I look at mine I only see two hydraulic hoses running to the cylinder that runs the three point hitch, I've looked and there doesn't seem to be and auxiluary line running to a remote hook up. Can anyone answer my question out there? thanks in advance
Jackmi
09-04-2006 13:31:54
 Re: Cockshutt 540 Hydraulics in reply to Allan Lance, 09-03-2006 16:54:56
My 540 came without the remote hoses, but had the remote lever on the right side behind the 3 point lever. I took out 2 pipe plugs, and hooked hoses and couplers to it. It will work the same time the 3 point is operating. Mine is a 1958.
Mike (WA)
09-04-2006 09:23:03
My 35 is the same set-up, I think- hoses run from the hydraulic pump under the seat, to the cylinder that lies horizontally under the left floorboard, and runs the 3 point. The hoses have couplers that you can disconnect, and then connect hoses to the implement. This disables the 3 point, of course, but if you have a trailed implement, that doesn't matter.
