550 hydraulics will not lift
Randy Shipley
09-03-2006 08:01:22
I was using the tractor when the hydraulics just quit. I pulled it down and found no evident blockage. I cleaned the filter and tryed it again but no help. The pump will empty the system through the remote valve lines. The relief valve has a small groove where it seats. Doesn't look big enough to be the problem. I need a good hydraulic flow chart to troubleshoot the system. Can anyone help?? My system only has one control lever. Also only one adjustment for system lever position on the outside (left side attached to the draft control). Any help would be greatly appreaciated.
