White 2-105 PTO disengaging
hayray
09-03-2006 05:10:36
After stopping to wrap the bale and then when opening up the tail gate the PTO disengages. I am snapping shear bolts sometimes when this happens as I think the PTO is slamming on and off real quick sometimes as I actuate the remote valve. Another local guy told me he had to rebuild the valve for the remotes on his 2 105 because he was having the same problem, but I called the dealer and they said that would not have anything to do with that, he told me to bale with another tractor and at least eliminate the baler as being a problem. Any ideas?
Thanks, Ray
glr62
09-03-2006 06:26:29
 Re: White 2-105 PTO disengaging in reply to hayray, 09-03-2006 05:10:36
Check the Pto linkage to see if it is fully engaging and not hitting the cab. Also, try not using the foot brake as that is on the same circuit as PTO.
