Super 55 Hydraulics - Revisited
Anonym
09-01-2006 06:37:49
Ok guys. I've finally brought home my Super 55 after several months of work. If you remember some of my old threads, the 3-pt would not lift and I'm ready to find out the problem and get it fixed.
I will apologize up front. I spent all my cash on the tractor and haven't purchased a shop manual, but it is on my list to do. I'm pretty mechanically inclined, so hopefully you guys can point me in the right direction.
The tractor is a 1955 Super 55 with an upgraded hydraulic cover (filter canister out the front) and auxilliary hydraulics. A pressure reading on the Aux. Hyds. only show about 40psi. The lift arms have raised on occassion, but rarely and not reliably. From doing some research and searching this forum, I've gathered that I'll need to:
1. Check the external Over-pressure Valve and make sure it's clean and working properly
2. Make sure all passageways through the aux. hyd. control box are unrestricted
3. Check the internal Over-pressure Valve and make sure it's clean and working properly
4. If any of the 3 above don't fix it, dig into the hydraulic pump for a possible rebuild.
Here are my questions that I need a little guidance on:
1. I checked to make sure the filter was in good condition last night and found that I don't believe it was properly installed. I removed the cylinder to find a ceramic (?) filter inside and a spring floating down the middle of the filter. How does this go together and what is the purpose of the spring? Do I have parts missing?
2. Where is the external Over-pressure Valve located?
3. Where is the internal Over-pressure Valve located?
4. What do I need to look out for when removing the hydraulic cover? Will I need to pay special attention to the gearshift mechanism, or is it contained and easy to see how it goes back together?
5. I'm assuming that I'll need to drain some of the hydraulic fluid from the reservoir to dig into these areas. Is the correct drain the rear-most plug on the underside of the tractor?
Thanks in advance for your help and patience on this. I know it would be simpler to have the shop manual, but please bare with me until I can get one. I greatly appreciate it!
Thanks,
Justin in Indiana
Matt Kane
09-04-2006 18:10:21
 Re: Super 55 Hydraulics - Revisited in reply to Anonym, 09-01-2006 06:37:49
My lift hasnt worked for years. I took apart my external hydraulic block and freed up my main valves, and cleaned everything. The external hydraulics works with a lever to put in on external or for your 3 point. My tractor had a stuck valve, and after cleaning it, I got my 3-point back. Not saying this is the problem, but check that valve, and make sure it"s pulled out. Otherwise, the fluid will run through a relief valve, which will raise the pump, but not give it enough pressure to lift the arms with weight on them. I overlooked the externals a hundred times, before i decided to mess with them.
Anonym
09-01-2006 13:04:58
Thanks for the replies guys! John, I sent you an email with my contact information in it. Feel free to be as lengthy as you want/need in your response. Everyone wish me luck!
Justin
in Indiana
J Schwiebert
09-01-2006 09:51:18
Hello: I don't have time untill late this evening for detailed answers. But the answere to #5 is NO. I will answer the rest of them in an e-mail as some will be slightly on the long side. Before you start on this send me an e-mail with a phone number. You need some information before you start. J.
jake4
09-01-2006 09:48:41
Draining the hydraulic section, remove the 3/8 pipe plug on the upper right side, insert a 3/8 nipple w/hose, start engine slow speed and when the 6-9 quarts are out stop engine to prevent pump damage. Set the trans in neutral, remove the shift lever, careful not to lose the 2 springs at the top. The cover can be removed now. There is a section on rebuilding the pump in the articles on the left column.
1755
09-03-2006 19:55:01
 Re: Super 55 Hydraulics - Revisited in reply to jake4, 09-01-2006 09:48:41
A guy told me one time when I was going to change a shifter on a 77 witch I did not get to that you need to take a pice of tin and make a u shape that you can slide in there and it will hold your springs in plase easaly under stood when looking at the botom side asuming it is the same the shifter goes strate threw a few inches and there is a spring on each side just sitting there I dont remember if it was between the bolts or on the oposet sides but slide the u shaped pise of tin in there to hold them in plase and then take the shifter out hope this helps
