Oliver Super 55 Parts
Mike Kushman
08-30-2006 18:24:13
Does anyone know where I can pick up some used or after market radiator grill assemblies and the grill center assembly for a 1955 Super 55? The tractor that I purchased is missing the center piece and the grills are so bent out of shaft that I question that I will be able to make them presentable.
Also I am in need of a new oil pan for a gasoline engine. It looks like someone hit something hard and it needs to be replaced.
RockinB
08-31-2006 06:02:47
 Re: Oliver Super 55 Parts in reply to Mike Kushman, 08-30-2006 18:24:13
An oil pan from a 66 will work also, and the chances of finding one in better condition is easier. Not that they are more plentiful, but the 66 has much higher ground clearance than the S55; therefore less chance of being bent/damaged.
J Schwiebert
08-31-2006 06:24:58
 Re: Oliver Super 55 Parts in reply to RockinB, 08-31-2006 06:02:47
Before you say that, I used to have and probably still do have a service bulletin that said the 66 oil pan was discontinued because the Super 55 pan would fit a 66 but there were some interference problems using the 66 pan on a Super 55. Not to be smart But one off of a super or 660 would work. Now what the problem was I don't remember. J.
RockinB
08-31-2006 13:15:19
 Re: Oliver Super 55 Parts in reply to J Schwiebert, 08-31-2006 06:24:58
John: Thanks for the correction regarding the 66 oil pan. I sure hate to pass on the wrong info.
AB
08-30-2006 20:25:05
For used parts try Kent at 903-729-8349. For new/aftermarket try Korves at 618-473-2855.
Matt Kane
08-30-2006 19:00:36
Maibach's Tractor in Creston Ohio, 1-800-808-9934
If I recall that center piece is quite pricey, I need one but Im waiting to pay it. Also check ebay, they sometimes have parts to these. I also think the oil pan can be from either a diesel or gas.
