3 pt hitch?
John Schneider
08-25-2006 10:32:01
What Oliver/Cockshutts, if any, had 3 pt. hitch. I have been trying to research the answer to this basic question and cannot seem to find the answer. Any help would be appreciated. Thanks in advance.
Hard Knocks IV
08-25-2006 17:24:23
 Re: 3 pt hitch? in reply to John Schneider, 08-25-2006 10:32:01
All the Canadian made Cockshutts could be had with a 3pt and as others have said there are several suppliers of 3 pt hitch for the first fleetlines on up providing they have hydraulics as a lot of the early fleetlines had a mechanical
lift.
Matt Kane
08-25-2006 13:37:50
Parts are available, some are getting more scarce. Parts may cost a little more than an N, But if its an 8N,9N,or 2N the little Olivers will run rings around them. My 55 has auxillary hydraulics, a factory swinging drawbar, 6 forward 2 reverse gears, independent PTO, and of course a 3 point hitch. They are dependable, and my little diesel is very easy on diesel. Alot of people who have made a switch love em. I was raised around small fords, and I like my Super 55 much better. Some newer models can be fitted with a 3 point hitch, And they have better horsepower.
Matt Kane
08-25-2006 12:53:16
I have a Super 55 Diesel, Good little tractor.
Im not sure what all models had them, but mine does. Also the 550 olivers.
John Schneider
08-25-2006 13:01:36
 Re: 3 pt hitch? in reply to Matt Kane, 08-25-2006 12:53:16
How do you guys find parts availability? Are the little old Olivers reliable? I currently have an N and I like the fact that parts are still over-the-counter for the most part.
John Schneider
08-25-2006 12:36:53
Interesting...I would love to get my hands on an 88 or something similar. All of my current implements are 3pt and there is no way I can replace all that. So far, I haven't come across an oliver with 3pt in my area.
old
08-25-2006 13:45:13
 Re: 3 pt hitch? in reply to John Schneider, 08-25-2006 12:36:53
Theres a lot of good aftermarket 3 points that work well on the Olivers. I have a 77 that I made one for, its ugly but works good. If you do get and Oliver you will never feel the same about that ford since the olivers will pull circle around just about any other tractor in the same HP range. I have a Ford 841 neb test say its 45 HP but my 77 oliver will out pull it and the 77 by neb test is 38 HP
MH
08-25-2006 11:10:57
Quite a few of them...On Olivers I am pretty sure they were an option on the Super series, maybe eveon on the fleetline?? I know you can get a aftermarket 3pt on the fleetline series.
