Oliver 88 Question's
Farmall H Pulle
08-23-2006 18:20:45
I have an oliver 88 that I pull. it has 3 7/8 m&w overbore pistions that are steped head. it has 175 psi of cylinder pressure. Dose this sound about right? What are some thing s that i can do to it with out stroking. How do most of you run ur carb ( Richer or leaner) I don't have axcess to a dyno right now so im just trying to get it close . what about timing and point gap. Will be repalacing with electronic later. what about gas to run and vavle lash setting. Thank you, Miles Rosenberger
turbin61
09-01-2006 15:21:30
 Re: Oliver 88 Question's in reply to Farmall H Puller, 08-23-2006 18:20:45
a lean motor is stronger than a rich motor. But don't make it to lean.
