Over / under Hydraul-shift
Bill sc. mn.
08-22-2006 18:44:02
I bought a 1650 diesel a month a go. The 3 speed slips in direct. So today we pull it apart. Not good, bearing, shaft ,sprag clutch. So looking for a good use one. thanks Bill i'm in southern Mn.
Bill sc. mn.
08-23-2006 19:22:04
 Re: Over / under Hydraul-shift in reply to Bill sc. mn., 08-22-2006 18:44:02
Well it looks like I will go with a rebuilt. Parts to replace old one would be more. What we think happen is sum one welded the sprocket to the input shaft which put stress on the 3 speed bearings. Any way Thanks for the help Bill
m kuhns
08-23-2006 08:50:16
Why buy a rebuilt one? Just fix the one you have. Parts are readily available for them. We always repair ours an have never had any problems. We buy parts individually, seals and all from Maibach's.
svehll
08-22-2006 21:56:10
I Have a over/under for a 1650 that I just rebuild. Input very good shape, new sprag bearing, new over clutch pack, All new seals and gasket. Call 512-633-5014
bradk
08-22-2006 19:30:30
Bill,
I bought a rebuilt over/under(3 speed) for one of my 1755's from Tom @ O'Brien county implement in IA.800-320-6224.He had used ones also,but for not too much more,got a great reman unit.Great folks to deal with!!! ~brad
Bill sc. mn.
08-22-2006 19:53:03
 Re: Over / under Hydraul-shift in reply to bradk, 08-22-2006 19:30:30
Brad may I ask how many dollars. Looking at all options. Thanks Bill
RGinMN
11-01-2006 06:13:22
 Re: Over / under Hydraul-shift in reply to Bill sc. mn., 08-22-2006 19:53:03
Bill, did you find an over/under? I"m looking for one for a 1650. Thanks.
bradk
08-22-2006 20:01:41
Bill,
It's been 1 1/2 yrs,but i think $800 used and $1200 reman.
It may sound steep,but I knew it would work and be reliable.Also didn't want to do that job twice by taking chance on salvage yard unit.~brad
