Super 55 Lift Arm
brian61
08-22-2006 14:19:28
Noticed a leak on the left lift arm today. Parts manual shows a seal on the cross shaft. Anyone know who might have that seal..?? How much of a job to change..?? dont look to bad looking at the parts book.
Thanks,
Brian
Ken MO.
08-23-2006 18:50:11
 Re: Super 55 Lift Arm in reply to brian61, 08-22-2006 14:19:28
I would suggest taking old seal out and cross the number over at Auto parts store.
AGCO Dealers seals are junk & they are not worth putting in. The only good thing about it is you get to put the seals in twice. I also suggest that you tape the splines on lift arm shaft so you don't cut groves in your new seals. If the lift arm bushings are wore to bad the seals will not fix the problem for very long.
Just my 2 cents worth
