Super 55 PTO clutch
Dennis(WA)
11-19-1999 11:00:04
Just bought a 1954 S-55. PTO clutch will not disengage. The lever does move back and forth somewhat, but not enough to disengage the pto. Are the clutch plates stuck together or what? I looked up in the inpection hole but couldn't see anything wrong. Anybody have an answer? Thanks.
Pete
11-20-1999 19:45:17
 Re: Super 55 PTO clutch in reply to Dennis(WA), 11-19-1999 11:00:04
Dennis - when mine did the same thing I found that the shifting yoke was worn out! This is a brass yoke that needs to be greased every 8 hrs of operation - If you don't belive it don't grease it and find out the costly way! and Dennis don't be afraid to split your S55 - It is simple and easy,takes 20 or 30 minutes and about 30 minutes to put back together. you just need to get a good ILLUSTRATED repair manual! Hope that yours is something simple but be prepared for more extenstive work. Good luck and E-mail me if you need help or have more questions.
Pete
Mongo
11-19-1999 13:06:42
If someone has set the clutch up tight, it will take several pounds of pressure to engage/disengage. It should operate with a "snap" or "pop". Also, often when there is excessive wear, the level reaches the end of travel before it will disengage. Sometimes when they are that worn, they will have enough side play to push outboard a little to miss the end stop and have it disengage. This is a real knuckle buster and would need fixing if that is the case. The 550 had a option of a forward shift lever that fit right on the shaft coming out of the housing that may be an option. If it were me, I'd loosen the clutches up some and see if it will work and then tighten it back up until it works correctly. In other words, I'd get real creative trying to get it working before I'd split the tractor. Hope this helps.
