Opinions on Super 88 D with turbo
K.B.-826
08-21-2006 20:05:45
I've got a chance to buy a Super 88 Diesel. It's got a big AiResearch turbo, fairly neat installation, execpt they don't have an air cleaner on it! Nothing! I guess they only pulled with it that way. Anyone ever put a turbo on one of these before, and what did you use for an air cleaner? I would assume you would want to use a dry filter. Just looking for any comments, good or bad.
dboll
08-23-2006 11:17:33
 Re: Opinions on Super 88 D with turbo in reply to K.B.-826, 08-21-2006 20:05:45
1650 pistons, a 310 head is a close fit with work done to one head bolt that is 1/2 a bolt off
old puller
08-22-2006 18:15:17
is it the one the slickster had at the georgetown show last weekend
Princeton Bill
08-22-2006 09:37:42
If you are only going to pull with it you don't need an air filter. Hopefully that is all you are going to do with the tractor. They probably did other things to it when they put the turbo on that would make the tractor a good candiate for never going back to field work.
dboll
08-22-2006 06:29:29
limiting factors are poor head flow , lanova injectors and the original pump if so equipped. put on a direct inject head ,good pump and cup pistons.
J Schwiebert
08-22-2006 17:59:31
 Re: Opinions on Super 88 D with turbo in reply to dboll, 08-22-2006 06:29:29
To increase my knowledge, who makes a direct injection 88 head and also who has the pistons for them?
