Oliver 3240 plow?
Mark N.
08-16-2006 19:40:29
I saw a 3240 2 bottom 3 point plow recently. It looked like the 3 point bottom mount pins were offset from each other up and down. If you were looking from the back of the plow to the front the right pin is lower than the left. It looks all factory. Is there a reason?
Josh in Pa
08-17-2006 06:45:43
 Re: Oliver 3240 plow? in reply to Mark N., 08-16-2006 19:40:29
The pin on one side is lower. When the tractor is plowing, one wheel is in the furrow and is lower. By building the plow with that side pin lower, the plow runs level when the tractor is tilted in the furrow.
Josh
