Cockshutt PTO slips
Al47
08-15-2006 16:04:00
A friend has asked me to help him service the PTO on his 30 cockshutt.I have no idea where to get parts or to adjust the PTO clutch pack.
Any information will be greatly appreciated,
thank in advance
Al
Irv Buttray
08-15-2006 20:29:01
 Re: Cockshutt PTO slips in reply to Al47, 08-15-2006 16:04:00
The clutch pack comes assembled with .050 shims under each of 3 brackets. If clutch plates are not worn outor seperated then remove shims .010 at a time and try engagining it on bench. should have a nice clean snap to handle. Shims are ussualli installed 1 .010 and 2 .020 or 3 .010 and 1 .020 for total of .050. if some have all ready been removed then you will most likely have to replace plates. I have a couple used ones but brand new reproduction would be best bet. let me know how I can help. Irv
J Schwiebert
08-15-2006 17:10:47
First of all how much effort is requirred to snap the clutch overcenter? Remember the clutch is a wet clutch so you will loose some oil when you remove the cover. I would try to adjust the clutch first. Remove the same number of shims from each shim pac. 2 or 3 should do it. Irv will have plates if you need them. Perhaps someone can scan or photocopy the instructions for you. Questions? J.
