2255 leaking oil
Now what happen
08-13-2006 16:39:47
I have a 2255 that was leaking rear end oil up by the clutch housing. Had local repair shop fix it. Started leaking again. Went for 30-40hrs then it stoped. Then the over/under oil started leaking back into the rearend. Nothing is leaking out anymore but the rearend is over full. Local repair shop will try to fix it again, But he has no clue why it is leaking like this. Any ideas on why? Thanks, Ralph
Randy as in Randy-IA
08-13-2006 18:47:02
 Re: 2255 leaking oil in reply to Now what happend, 08-13-2006 16:39:47
Hi , I probably shouldn't say anything since I only have one 1755d but I agree with Marc . If it's built like mine the three speed is in front next to the engine not in back next to the transmission . Mine has the driveshaft between it and the tranny . But maybe the larger engine in a 2255 puts the three speed next to the tranny which would eliminate the chain coupler and drive shaft . It's easy enough to look in and find out . If there is a driveshaft into the tranny then it's got to be the hydraulic oil leaking down into the rear end . JM2CW ...Randy
olidlr2
08-13-2006 18:51:49
 Re: 2255 leaking oil in reply to Randy as in Randy-IA, 08-13-2006 18:47:02
2255 dose not have a chain
olidlr2
08-13-2006 18:15:02
Yes, you're over-under can leak fluid into the rear end. 95% of the time, the seal between the input and output shaft of the tork goes out. The question I have, is are you using ATF in your tork? That way you are for sure your tork is leaking into your rear end because of the red tint in the oil.
Marc Smothers
08-13-2006 17:17:02
Hello. First off the over/under oil cannot get into the rear end.. It sounds to me like your PTO is leaking oil into the rear end.. How is your hydraulic fluid, up to level??? Usually if your rearend gets full, it is the pto leaking oil into the rear end.... Good luck, Marc
