Stearing motor seal replacement
RBTXS
08-13-2006 16:16:35
Well, I got my 1955 radiator removed and taken to the radiator shop, so I now need to fix the leak in the stearing motor under the radiator. According to the parts book, there are 3 o-ring seals below the cover. One is called a "Quad Ring". Is this a regular o-ring (3/16 x 2 1/2 ID), or is it something you can get only from AGCO? The part # is 155 788A. Also, are there any special procedures I need to follow in order to change these o-rings correctly? Thanks especially to Merlin in NW arkansas for the radiator removing advice.
MH
08-14-2006 11:23:40
 Re: Stearing motor seal replacement in reply to RBTXS, 08-13-2006 16:16:35
Shovelman is right, did the one on my 1650 and it was a straight forward repair.
Shovelman
08-13-2006 17:56:56
If the 1955 unit is like the 2-105 and 1650 (I believe the steering units are all similar) a complete seal kit is available. I just did my 2-105 steering unit and the kit ran about $20. from Maibach's.
The kit comes with the quad ring (special), o-rings and piston seals. I just clean everything up really well, dress up any imperfections with emery and assemble using Vaseline on the seals, pistons, etc..
Good luck,
Scott
