need block line bored on 1750
thhill
08-13-2006 09:42:59
Anyone know who can still line bore the mains on my 1750 Wackashaw . Rear main spun in it. Crank mics at 30 thou. So need to grind crank and line bore journals. Somewhere close to northeast kansas. Its getting hard tofind shops who can. Thanks
ejr-IA.
08-13-2006 18:15:57
 Re: need block line bored on 1750 in reply to thhill, 08-13-2006 09:42:59
If you have it line bored check your rear engine seal so it is centered on the crank.
cobroller
08-13-2006 15:31:23
You will also need check the crank and cam gear clearance
j105
08-13-2006 13:29:12
you might try Automotive Machine,Inc in Emporia. I know that's more east central Ks. But talk to Mark Carney, he does good work.
j105
08-13-2006 13:32:03
 Re: need block line bored on 1750 in reply to j105, 08-13-2006 13:29:12
how about i give you the number. 620-343-2096.
J Schwiebert
08-13-2006 12:08:46
First of all is this agas or diesel? If a diesel, make darn sure the crank grinder can do a Rockwell C test on the crank. Spinning a bearing can take the hardness out of the crank. If that happens some one can use the crank for a gas engine but not a diesel. Second item: I don't know if they are still available but there nodular replacement caps available. If they are available use it and double check the rest of the mains. Do you know who thhe automtive engine rebuilder association is? They have a directory and should be able to point you in the right direction. A little humor here. A local business needed to have a crank ground. The best quote was in Japan. Of course that crank is about 15 feet long too.
Kruse
08-13-2006 14:24:21
 Re: need block line bored on 1750 in reply to J Schwiebert, 08-13-2006 12:08:46
A little more humor here. (Funny, but TRUE) My sister is an engineer for a natural gas company. She is partially in charge of the pumping stations where they take the gas out of the ground and pressurize it and pump it into the undergound pipelines. They use some huge inline engines to do this. One of these inline combustion engines broke a crankshaft and she was in charge of replacing it. The crankshaft alone was $250,000. That was the cost about 15 years ago that price was without labor to have it installed. Maybe our tractor repairs aren"t so expensive after all.
thhill
08-13-2006 14:15:37
thank you both for the info.Emporia isn't that far. It is a deisel, it was idling when it spun. Do yo know if it will have enough piston clearence it line bored cold raise the top of the piston 10,thous. Ive never heard of the insert idea but might check into it.
The hard ness test I'll ask him about.Thanks
