oliver sickle mower
TC NWTN
08-13-2006 08:46:53
I just acquired an oliver sickle mower with 2 wheels on the back. I am trying to restore it to pull behind my 77 rc. It is manual lift. If anyone has a picture or any info as to the model #or how it is painted , I would appreciate the help. Thanks , Tommy
TC NWTN
08-14-2006 16:11:17
 Re: oliver sickle mower in reply to TC NWTN, 08-13-2006 08:46:53
Thanks for the replies. Another question I have is the large round rod that holds the inside part of the cutter bar shoe supposed to be bent or is it supposed to be straight. I am talking about the bar that hold the cutterbar assembly and lets it work up and down and is attached at the other end at the gearbox frame. thanks, Tommy
centrlilbaler
08-14-2006 12:14:16
Misread the post sorry guys
centrlilbaler
08-14-2006 12:05:28
I've posted some pics of my #82 at
http://www.hartparroliver.org/gallery/view_album.php?page=1
MH
08-14-2006 11:18:08
I've got a manual somewhere for a model 22, I will try and dig it up this evening.
centrlilbaler
08-13-2006 19:23:30
I"d bet its a #82. I have one and it sounds exactly like it. I"ll try to find some batteries for the camera and take some pictures
evielboweviel
08-13-2006 13:08:27
uncle carl had one of them on the 66 when I was a kid. Learned how to mow with a farmall cub then later tried to mow with that one never was strong enough to lift the bar quick to make the square corners. He switched to a pull behind about 70. I have one for my 66 that has hydraulic cylinder mount and pto pass thru for conditioner. need to get a pitman for it and try it out on the 66 some time.
Ron
J Schwiebert
08-13-2006 12:12:02
I would check with the museum and ask if they can scan a picture of the various model 21 and 22 mowers and then you can determine which one you have. There will be red and yellow on them and depending on which one the green will be darker than the green on later tractors. My 2 cents worth. J.
