Follow-up 660 Starving For Fuel Posted 8/4
Hillcrest Farm
08-12-2006 18:19:33
I installed the tee just before the Bosch unit.
The pressure just barely makes the gauge move on a 0-35psi gauge. When you remove the gauge, you can get some volume of fuel when you use the primer handle on the pump.
J Schwiebert
08-13-2006 04:29:29
 Re: Follow-up 660 Starving For Fuel Posted 8/4 in reply to Hillcrest Farm, 08-12-2006 18:19:33
It is starting to sound to me like your mechanical lift pump on the other side is worn like in the linkage and it is not delivering the fuel. Pull it off and see how much wear there is in the follower that rides against the cam and the arm that works the diaphram. Also take a look at the check valves. Good luck! Questions? J.
Hillcrest Farm
08-13-2006 06:27:19
 Re: Follow-up 660 Starving For Fuel Posted 8/4 in reply to J Schwiebert, 08-13-2006 04:29:29
This pump has the strainer installed. Any suggestion on replacement pump supplier of will I need to get it rebuilt?
