Steering Box Blues
Mark Miller
11-16-1999 18:59:12
My Oliver Super 55 Steering Box is well worn. The splined and threaded end on the vertical steering shaft is stripped. I assume I could have a this section built up with weld and re-machined. Does anyone know what the spline definition is for this item? Also for the output shafts Was this shaft heat treated in any manner? I have read this machine was designed to mimic the Ford 600/800 Series of tractors. Are any of the components interchangable? I was wondering on the front steering components especially.
Mongo
11-17-1999 21:28:52
 Re: Steering Box Blues in reply to Mark Miller, 11-16-1999 18:59:12
There are sixty ball bearings to the steering box. There are two bearings with races above and below the worm shaft. These are all still available. Also, in the front end the thrust bearings are usually the first to go. They are only $6 each from the dealer. The bushings are also available, if I remember right it was either $30 or $60 a side from the dealer. The seals to the front hub are the most exspensive. They don't look like anything much and cost $45 a side! I'm not sure on the specs for the shaft. The dealer I have locally sells reconditioned steering boxes for about $350. They have new everything. Hope this is of some help. Maibach Tractor in Ohio does a good mail order business if you need parts.
ro
11-19-1999 16:42:51
 Re: Re: Steering Box Blues in reply to Mongo, 11-17-1999 21:28:52
Hello,
You might give Shuck Implement a call in Lawrence, kansas. They have a lot of Olvier salvage and used parts.
Good luck
