Oliver 70 lights
lucasd
08-10-2006 13:50:53
I just finished restoring an Oliver 70, and everytime I turn on the lights, I blow a fuse. Any thoughts on why this is happening. It is 6V and there is a 30A fuse in the switch. When the fuse if bypassed with a wire, the wire gets really hot. Thanks for any help or suggestions.
Ken Loewenhagen
08-10-2006 16:54:31
 Re: Oliver 70 lights in reply to lucasd, 08-10-2006 13:50:53
Disconnect all lights. Put a fuse in and turn the light switch on. If you blow a fuse, the problem is in the wiring or the switch. Check it out. If you don't blow a fuse, connect one light at a time. If you have a bad light, the fuse should blow when you connect it.
bradk
08-10-2006 16:02:04
Another trick is to have a helper look real close at the lights one at a time(works the best in the dark) and see which light isn't working at all while very momentarily bypassing fuse.
The light not working is the power short to ground.Should help narrow it down.~brad
old
08-10-2006 14:12:10
Look the wires over real good and any place they pass through metal sounds like you have a short some place. Common places to have a short if where the wire goes in to the light bracket/houseing
